vanette carb air filter cover dohicky thingmabob watchmacall
dirtyleppa
aka: leppa
Post by dirtyleppa »
i need a vanette carb air filter cover dohicky thingmabob watchmacall so i can fit an air filter to the wags.
help a poor african out
its the blue thing
mint16
aka: Brendan
Re: vanette carb air filter cover dohicky thingmabob watchmacall
Post by mint16 »
what?
why would you want to use that?
its all kinds of fail, sorry dude.
i have a spare 910 airbox that would do a way better job! what happened to yours?
72 Datsun 1200 Wagon
dirtyleppa
aka: leppa
i have a factory 910 airbox, but it fouls on the fuel line, and that caused the fire last time.
it doesnt need to be specifically a vanette 1 but anything similar. i wanna fit a piece of pipe and fabricate a custom intake with a pod
why are they shit?
mint16
aka: Brendan
Post by mint16 »
im pretty sure the vanette intake pipe wont fit on your carb, as your carb has a much bigger intake diameter.
it was never fitted to any other a-series vehicles.
aesthetically its not good.
what about airflow volume compared to stock airbox? just a thought.
id rather see you fit a single sidedraught carb or a downdraught weber carb, i think youd get a better result.
i think a weber 32/36 from a ford 2L would be a good upgrade, and could be quite affordable.
i think all the effort involved fitting the pod setup wont be worth it. unless you do it on maximum cheapness for experimentation, then go hard!
kartboy
aka: Hayden
Post by kartboy »
Hey man. I have got one here taking up space on my garage floor if you want to try it some time to see if it fits
dirtyleppa
aka: leppa
kartboy wrote:Hey man. I have got one here taking up space on my garage floor if you want to try it some time to see if it fits
thanx hayden, ill get hold of you some time
mint16 wrote:im pretty sure the vanette intake pipe wont fit on your carb, as your carb has a much bigger intake diameter.
ive got twin SU carbs here that i may fit. im not doing it to gain any more performance, im just not a massive fan of having no filter on the engine like i used to
I have one also.
