kartboy
- aka: Hayden
Post
by kartboy »
Got my ute going yesterday with the A15 and twin dellortos.
Problem is it will start with the key but it won't turn off with it, have to either stall it or pull the coil lead off
anyone know what the problem may be??
torqued
- aka: Adam
Post
by torqued »
fuel cut off solenoid?
kartboy
- aka: Hayden
Post
by kartboy »
Has got a mechanical fuel pump so don't think it has one??
grant76
Post
by grant76 »
yeah its a hexagonal fitting screwed into carb on engine side towards front of vehicle with a wire coming out of it
fast4motion
- Datsun Dreamer
- aka: Brent
Post
by fast4motion »
If it's got twin dellorto's it won't have the fuel cut-off solenoid.
I suspect your coil positive terminal is wired to a constant 12V source, when it should be wired up to the ignition switch.
grant76
Post
by grant76 »
oh right, didn't read that part
Jabo
- aka: Jasper
Post
by Jabo »
Hey sorry to hijack but good to see you got those carbs running
kartboy
- aka: Hayden
Post
by kartboy »
nope coil only got ignition power, just went out and checked it
torqued
- aka: Adam
Post
by torqued »
So is it like it is dieseling?
160jsss
Post
by 160jsss »
You could have it too lean on the mix is it when she's hot might be dieseling
Violet - ??????
