James Z31 Engine Blueprinting
Re: James 85 Z31 300zx
Niice! Ive grown quite a liking to the Z31 lately. There is a nice blue one with black flares in the states and it is so freakn sweet!Keep up the hard work
Yeah its a pretty famous car
I know its this one because i frequent the Z31 Performance USA web forums
http://home.comcast.net/~movistar323/P1000877.JPG" onclick="window.open(this.href);return false;
That particular car is an 85 body with an 88 rounded front end swap and a shaved rear bumper, it is actually a drift car / track hack
Welcome to the site James. Good to see you've taken the time to register and share your build thread with us Datsun fiends!
(btw, it was me who pm'd you at oldschool)
Hey there Bart
Yeah i figured that one out, thanks again for the invite/suggestion to register
save yourself some work,and use r31 turbo (hr31 gts-x) slip on front hubs that you can redrill to 5 stud very easily.
using z31 hubs, like you say, they need to be machined down but they also space the disc out approx. 5mm further. this means you will need
spacers behind the caliper. r31 hubs dont, as they fit straight up. and it also gives about 5mm more gaurd clearance too...
im going through all this on an S12 at the moment, which is virtually identical to your front end.
I actually have the opportunity to buy the slip on style rare impossible to find 88 z315 stud hubs,
However i can get mine machined for free and i have a contact in the USA who is getting me the correct length wheel studs for around $50 NZD to account for the thickness of the rotor.
its personal choice but I am happy with my solution considering I already have the hubs.
haha yeah i got offered a set of those for $400 each, and passed it surprisingly
im going the same way you are with z31 hubs now, as the wheels i have (9" wide) foul the strut with r31 hubs, but clear by about 2mm with the z31 hubs. apparently there is a disc that bolts to the back of a 5 stud z31 hub that suits the 4 pot r33 calipers. the Aussies i talked to said it was a mitsi Verada or simular. im trying to find out as this would pull back 8mm of gaurd clearance from the slip on discs. my rims already about 15-18mm outside the gaurd
- aka: leppa
welcome man, looks like a good base for a sweet ride. look forward to more
I am aiming for a WOF on Saturday
Hope to get out and about and meet some of you Chch Datsun guys !
Choice car! Great work.
keep the pics coming
