But I have a ca20 and a ca18det long block occupying my back shed, and since I'm hoping for my flowbench to be finished sometime next month, I'd really like to build a motor.
And there lies the problem, I have no money or car to put it into, so thought I would float the idea on here and see if someone would be keen to get a rowdy 2L ca built?
Basic plan is
86mm bore by 88 stroke = 2044cc
Ca18det block - in stock
CA20 crank - in stock
BMW rods - in stock
86mm RB25de pistons - need to be acquired
ca18det Head ported by me, 3 angle valve job outsourced
Extractors made to suit cams CR etc. (would need to be done after installed in car if local)
Built up and reground cams - from Franklin cams
Induction I was thinking probably injection with custom plenum, made by me and probably just get the stock ecu chipped by Dan to keep cost down
Or 40mm R1 bike carbs but would need to sort out some way to do ignition
I'd also need to sort flywheel, probably an rb20 one at this stage *I think*
Anyone keen?
If anyone is serious, let me know and I can start pricing up stuff and and come back with a more specific price
It WILL be more expensive than buying a ca18det
Also this is not a "why bother just buy a ca18det thread" so leave the forced induction talk out of it please (I'm looking at you bart!)
