Hey just wondering if anyone has put a tacho in their 180b and where they put it?
would replacing the clock for it look OK?
Placement of Tachometer for 180b
- aka: leppa
Re: Placement of Tachometer for 180b
as long as its not right on top of the dash, it should look fine. nothing ticks me off more than a huge tacho right in your line of view on top of the dash
Particularly with a big as shift light, big bore and Auto!
- Mikewazowski
- aka: Michael
I mounted my tacho on the steering column, offset so that it fit just below and in between the speedometer and the clock. It's a good visible position and doesn't block anything else. My tacho is and oldschool type though, and is not as huge as some of the new ones.
i have one on top of my dash, with internal light and i dont mind it at all, but the needle floats a bit is that normal? it got wired in by electrician
