James Z31 Engine Blueprinting
DJZ
Re: James 85 Z31 300zx
Post by DJZ »
My mate has used Spray Store before, said they were pretty good.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
nick_m
Datsun Master
aka: Nick m
Post by nick_m »
yeah spray store would be my pick too
85_Z31
Datsun Master
Post by 85_Z31 »
nick_m wrote:yeah spray store would be my pick too
Cheers Guys
I will give them a call when i get back From down South ( leaving in couple days time )
and Nick, as you can see i just gave it death with the welder and it came up mint, i probally had to do a lot more grinding and filling than you would have had to, but i think the end result is tidy enough.
nick_m
Datsun Master
aka: Nick m
Post by nick_m »
yeah dude looks good, don't know what you needed me for :D
85_Z31
Datsun Master
Post by 85_Z31 »
Of course you guys remember that I casually nailed on some 4 Pot Front Brakes a little while ago
so now its time to convert the rear end from 290x10mm ( solid ) to 290x20 Vented :D
Of all things I reckon a Jaguar Rotor is going to be a way to go because i can't find any other rotor with a low enough offset
( so that the rotor doesn't hit the caliper )
So i think its time to bust out the cardboard and the Glue to make a "Mock up" life size section of the rotor to check Fitment Before I Drop $220 on parts I can't use.
85_Z31
Datsun Master
Post by 85_Z31 »
Been out to do some measuring
OD of Rear Hub is 154.8 - 155mm
Image you zoom in you can read the measurement , so that definitely fit inside the Jag Quoted measurement of 159mm
Measuring Between the Pad Carrier i get 24mm
Using a straight edge the face of the Hub to the Edge of the pad Carrier is 43mm
43m ( hub to pad carrier ) minus 12.1 leaves me 31mm from the face of the hub to the center line of where the rotor needs to be.
By looking at the Jag Drawing the inside of the rotor hat Minus half the thickness of the rotor leaves 15.5 ( face of hub to center line of rotor)
So by those measurements this should completely work providing I use a 14.5mm Spacer
If somebody cares to check my maths that would be appreciated.
It would be Idea to use a rotor with slightly more offset , but it seems to get a rotor with under 42mm total height is extremly rare as most of the 2mm vented rotors use a total height of 57mmto 80mm
nick_m
Datsun Master
aka: Nick m
Post by nick_m »
possibly stupid queston but did you check out the DBA Catalog, i've always found that useful for rotor hunting
DJZ
Post by DJZ »
You can't use factory late Z31 rotors?
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
85_Z31
Datsun Master
Post by 85_Z31 »
DJZ wrote:You can't use factory late Z31 rotors?
late Style Z31 Rotors have a total height of 57mm ,
this is what happens with the early style rotor that have a total height of 47mm
the DBA catalouge was helpful, but the Brembo Catalouge in most cases shows a full drawing with better detail of the same rotor.
DJZ
Post by DJZ »
Sorry, reading this on a cellphone hah.
So you are using late Z31 calipers? What's the reasosn why the rotors to match don't work? I know the control arms and companion flanges are longer, are the caliper mounts in a different place?
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
