Garage clean out, random stuff cheap/free
Sell stuff
DJZ
Post by DJZ »
I'm having a bit of a garage clean out and have the below stuff taking up room. If it doesn't say free next to it make me an offer and I'll more than likely take it.
FREE 1 x Lightning Audio amp, not going
FREE 1 x warrantable 205/55/16 Bridgestone GRID II
FREE 1 x R30 coupe factory steering wheel in grey, is missing the centre currently but it's around here somewhere
FREE 1 x LD28 rocker cover
2 x L28 standard Nissan OHC rocker cover
1 x LD28 custom made sump, was in a Volvo. Bowl is at the rear, apparently holds about 10L of oil, comes with extended pickup
1 x LD28 flywheel, this is the correct flywheel with the timing mark and sandwich plate with the hole in it
1 x R30 L20ET factory clutch, pressure plate and cover
1 x set of 6 L series flywheel bolts
1 x pair of not legal 5x114.3 wheel spacers 25mm
1 x RB20DET oil pump
1 x RB26DETT factory oil pump
1 x oil cooler, it's a tube and fin made for a VW
1 x oil filter housing RB20DET
1 x rear main seal housing RB20DET
More to follow
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
DJZ
Re: Garage clean out, random stuff cheap/free
Post by DJZ »
FREE 1 x pair of R31 radius rods
FREE 1 x VG20ET air flow meter, untested
FREE 2 x ~1m lengths of -8 blue fancy pushlok hose, used
FREE 1 x gearbox crossmember from a manual R31
FREE 1 x gearbox crossmember, unknown but looks similar to the above
1 x 12" electric fan, used
1 x RB26 set of factory pistons w/rods, a couple of are scored and some have detonation marks
1 x one aluminium RB26 engine mount bracket, not sure which side
1 x R200 diff rear cover
1 x RB20DET sump & pickup
1 x R30 L20ET power steering pump
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
DJZ
Post by DJZ »
There are probably other bits and pieces lying around, I have quite a few L28 bits, cranks, pistons and rods, little bits and pieces like cam pulleys, crank pulleys, etc etc if anybody is looking for anything. I have some RB20 motor bits too but nothing large.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
What are you after for the Starter?, could be good to have a spare Z one.
DJZ
Post by DJZ »
How does $20ish sound?
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
Sounds good
stickers
Post by stickers »
what rb20 parts do you have man and how much for fan??
I think the datsun will need the plates OMGWTF when its done :D
DJZ
Post by DJZ »
Mostly just bits left over from stripping a block, sump and pickup, oil squirters, knock sensors etc I thought I had some pistons and rods but I haven't come across them yet.
$20ish for the fan?
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
Would the knock sensors be interchangable with other nissan engines?
DJZ
Post by DJZ »
They have funny plugs on them but are screw in like most of the old Nissan engines, I've got an L20ET knock sensor too which just has bullet terminals.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
