Z18et Wiring diagram
heres a z18et wiring diagram i drew up since theres barely any around
- aka: Dan
Re: Z18et Wiring diagram
I have a better original diagram than that if it's any help to you?
Sent from my tegav2 using Tapatalk
- Area Reps
- aka: shane
man do wiring diagrams not get any more simple than that ??
- aka: Dan
Thats the point. Its a bit too simple
Doesn't give enough info
Sent from my GT-I9100 using Tapatalk
thats all I used to wire up my mates z18et into his bluebird I had a pin out of the ecu and drew the diagram to show him how it was going I’m no expert at drawing diagrams was my first try so gave it a shot and that’s what I got so hopefully it might help someone else out I have a original somewhere but it is very low quality and is barely readable so do share
