hey guys
hope someone could help me..
hw cn we differentiate
a SSS cylinder head over a standard head
on L16/L18 Lseries engines..
is valves any bigger ??
inlet port size
what is the correct valve lash be on L16..if it has a A87 head with L18 cam..
umm second question is
wat should the correct oil pressure when idling on L16??
thanks alot in advance..
cheers
nathan
chch
SSS cylinder head on Lseries
- 160jsss
Re: SSS cylinder head on Lseries
Hi Nathan
I'm being a arse but get this book you need this book as a Datsun owner it will keep you reading it over and over .
I was looking for mine to answer your question but can't find my dog eared oil stained copy
http://www.trademe.co.nz/motors/car-par ... 776508.htm" onclick="window.open(this.href);return false;
Violet - ??????
thanks man
seems like me question was abit confusing
but i got this link in the end..
http://www.olddatsuns.com/html/tech/head_ID_2.htm" onclick="window.open(this.href);return false;
i also bought a SU carb setup will install it soon..
thanks alot again
thanks alot again
For what it's worth, most of the A87 heads I've seen have been closed chamber.
