Four pot calipers front 2 pot rear.
Four discs freshly machined.
Rear pads good, front worn.
All hoses and clips un cut.
Full handbrake setup.
Was going to use for my 1200 but want to run 13s so will opt for something a little smaller.
15 in rims fit over these fine.
Including machining this setup owes me around $500
Make an offer need to get this car on the road!!
Z32, gtst full brake setup... Everything there!!
Re: Z32, gtst full brake setup... Everything there!!
are you sure 15s fit over these cause i have r32 gtr brakes witch i think are the same maybe slightly different but i need 16s?
Non Brembo GTR brakes are 296mm OD where the Z32 brakes are 280mm.
I think it depends on the profile of the inner surface of the wheels. I also have GTR brakes but 15" wheels with 296mm discs. The inner surface of the wheels is flat and there is about 10mm clearance between calipers and wheel.DJZ wrote:Non Brembo GTR brakes are 296mm OD where the Z32 brakes are 280mm.
15's do Indeed fit over the 280mm R32 GTST rotors and 4 pots. you may need an adapter or spacer to get proper clearance to the spokes
and like so they fit just fine....
- Datsun Dreamer
- aka: Chris
I also have some 15x7 ROH wheels with massive behind spoke clearance that clear the 4pot fronts.
If they don't sell here, I'd recommend listing them on SilviaNZ. I'd imagine they'd sell for at least $500 there.
These are sold, thanks.
