I'm rebuilding the engine as stock basically. The car is all stock probably one of the few left in the country that hasn't been modified. So I don't want to ruin it by putting in a modern engine, or even an L20B for that matter (I have a W block but will keep it for another 1600).
Where would I get some flat-top pistons like the OE ones?
The stock compression is 9.5:1, which could probably go up to 10.0:1 on 98. That will be gained by planing the head assuming enough valve clearance with the standard cam.
Any recommendations in Christchurch for a good engine reconditioner for the short block? I heard a while ago that Cylinder Head Specialists is good for the head, is that still the case?
Once I get it back on the road hopefully I will make some of the club runs.
1600SSS motor where to get OE flat-top pistons etc
Re: 1600SSS motor where to get OE flat-top pistons etc
gidday, and welcome to the site,there is a guy on here called hspwr, he has his own parts business in napier and owns a 1600 as well, i think he has a thread in the parts and services thread. try him for the pistons,and then cliff bond on ferry road for the machineing etc, treated me very well when I delt with them, and a friend had great service from them too. if you need a machanic to put it all together datto devil is an a grade mechanic, and there are other very handy people on here who could put their hands up for such a task.
start a build thread and post some pics please.
CHS do good quality work.
Last motor I built, I used Dirk Stobbe at precision engineer in southbridge. (Just as you go into goon)
But apparently the some guy out at greta valley is the man for building hot motors.
- hsepwr
- aka: Craig
I brought in some keith black pistons from the states for my L series which were really poor quality so sent them back and ended up getting a set mahle's which were gret quality so would recommend getting a set of them. i could look into a set for you as mine was a L18 and yours L16.
When you say flat tops i take it you mean they still have the 2.5mm small dish in the top and not dead flat.
- denpal
- aka: denpal
The L16SSS does have dead flat pistons. There is no dish and no valve cutaway either. I just need a set of cast flat-tops of good quality.hsepwr wrote:I brought in some keith black pistons from the states for my L series which were really poor quality so sent them back and ended up getting a set mahle's which were gret quality so would recommend getting a set of them. i could look into a set for you as mine was a L18 and yours L16.
- denpal
- aka: denpal
Update - the head has been planed excessively, so it's marginal to use. Goodness knows what is going on as I can see marks in the top of the bore where the exhaust valves have touched the bore edge. Been having second thoughts about modding the car. A big capacity L20B would still look fairly original, with a pair of Z SU's. But it would go a lot harder and pull like a train in the higher gears which is what I want.
Well after a few minutes research I can get a L23 off Troy Ermish in the US for $US2600, plus sea freight $NZ250 approx. That is 89mm bore and 92mm stroke, rebuilt and assembled long block and balanced too.
Almost 200hp and 200ft/lbs of torque with a pair of twin-chokes. Allowing 22% drivetrain loss that would be 156hp at the wheels, say 150hp. Probably around 140hp with the Z carbs or 94kw.
That isn't much more than the L16 will cost to rebuild.
He has a very good name as a Datsun man.
http://www.ermish-racing.com/onlinestore.cfm" onclick="window.open(this.href);return false;
