wanted to borrow ......spring compressor's
luke
Datsun Addict
Post by luke »
As above..... but including the owner of them to help.
1972 1200 coupe KB110
85_Z31
Datsun Master
Re: wanted to borrow ......spring compressor's
Post by 85_Z31 »
I have some.
If you are willing to bring struts out to Rangiora on Sunday I can do the "owner helping part"
Send me a pm Luke
James
I've got some too, happy to help.
Kitch
Post by Kitch »
put your size 10 boot on the strut assembly and undo the top hat nut with a long handled socket wrench, and just shoot it off! (dont aim at your vehicles at the time though!)
You should not need compressors to install the avenger springs either, as you should get your shock shortening & spring cutting sorted so that there is only a couple of mm of preload on the springs when you assemble the shocks.
luke
Datsun Addict
Post by luke »
i only ask as bart said i need to do a mock up to see how much of the spring to cut etc etc when the car is on all 4s to see ride hieght etc.
or is this not nessesary? front end is already out im just waiting on the mock up to finalise how many mm to slice and dice before getting bellamy and east to reshape the top and the likes
brocky41
aka: Brocky
Post by brocky41 »
Kitch wrote:put your size 10 boot on the strut assembly and undo the top hat nut with a long handled socket wrench, and just shoot it off! (dont aim at your vehicles at the time though!)
This trick is awesome for putting holes in either garage roofs or walls (seen aftermath) also breaking windows and putting dents in panels lol
sr1600
aka: Mark
Post by sr1600 »
Also ratchet tie downs work well for max danger
and ribs / armpits :P
luke
Datsun Addict
Post by luke »
its for re assembly you fools! one strut top did claim my beer though :deadhorse:
woodies72coupe
Post by woodies72coupe »
When you have finished can you pop over and fit mine too?
