1200 coupe lowering
luke
Datsun Addict
1200 coupe lowering
Post by luke »
i have installed the 60mm shortened monroe shock inserts and had bellamy and east shorten and reshape my springs..... but its still too high for my chosen tyre/rim combo. back looks great etc but front i want another 40mm lower.
i wanted everything to be able to go back to factory if need be when i started this project, but since now i have another 2 spare sets of disc brake struts im open to creativity.
im gonna be running ssr mk3s 13x6.5 +10 with 165/65r13 tyres, and i want the front to match the back in terms of top of tyre to bottom of guard.
help is appreciated
1972 1200 coupe KB110
braasmonkey
Site Admin
aka: Braasy
Re: 1200 coupe lowering
Post by braasmonkey »
luke wrote:i have installed the 60mm shortened monroe shock inserts and had bellamy and east shorten and reshape my springs..... but its still too high for my chosen tyre/rim combo. back looks great etc but front i want another 40mm lower.
help is appreciated
Someone chime in here with whether this is correct or not, but I don't think you're going to be riding level with the wheel/tyre spaced out the same in the front and rear, as the guard lip is higher in the front? To achieve this you will need to have a bigger wheel in the rear or taller tyre.
Someone correct me if I'm wrong...
- Braasy
luke
Datsun Addict
Post by luke »
help is appreciated
Someone chime in here with whether this is correct or not, but I don't think you're going to be riding level with the wheel/tyre spaced out the same in the front and rare, as the guard lip is higher in the front? To achieve this you will need to have a bigger wheel in the rear or taller tyre.
- Braasy
brassy dont be so negative! ;) . iv seen some outrageously low 1200s around, i just want as low to match rear, not opposed to raising rear up slightly but front still needs to drop more
braasmonkey
Site Admin
aka: Braasy
help is appreciated
- Braasy
Top of tyre clearance versus level ride height are two different things. Low and level clearance, no problem. The same top of tyre clearance both front and back, I don't think so. Await confirmation :)
- Braasy
torqued
aka: Adam
Post by torqued »
Raise your strut towers :lol:
gingofthesouth
Site Admin
aka: Ging
Post by gingofthesouth »
torqued wrote:Raise your strut towers :lol:
Actually, my camber adjustment top hats kinda do that by putting the nut position higher than the level of the tower...
gingofthesouth
Site Admin
aka: Ging
1200 coupe lowering
Will be swapping these out with some other camber plates I have though...
Luke I think Brassy is on to it. So measure the ground clearance at the front and rear of the sill, near each wheel, yes sorry that will mean getting down on your hands and knees, (I know you're up for it). this is the measurement that needs to be the same. On Sedan wheel arch clearance is greater front to rear.
Luke you need to change spring length or lower the spring perch height (on the strut) to lower car. Shifting strut top won't do it, raising spring seat or tower top would, but not moving the shock mount only. Looks like your guess was a little out, but on the good side. You can cut more off, you can't cut more on.
woodies72coupe
1200 coupe lowering
Post by woodies72coupe »
Luke if you can get this right? Then I can just copy your set up? Lol.
