havent really updated in a while, front half of coupe plus firewall etc has had ratmat treatment.
circletrack is shortening my driveshaft 40mm.
dans made progress on the wiring loom etc just waiting on some things from the states.
nick m made me an intank setup using a 6cylinder fuel pump from god knows what, but will easily keep up with my fuel needs, got wal to silfloss and paint it aswell!
decided on a set of wheels il be running. brendan kindly came along for the mission to geraldine for company and i suspect to thrash my ute around a bit. i bought the set of 13x6's and then perked brendans 13x7.5s.
they are Enkei Apache -6 rear and +10 front, chris has been super neat and chucked some tyres on for me to test fitment/stretch etc, will be looking for something around 175/60s i think as 165/65 is just stupid amounts of stretch and i dont need it as wheels are mostly in the guards.
getting mr van beek back for another installment of alloy magic, hopefully he can create me a bracket for my vr trigger wheel sensor AND make the actual trigger wheel itself.
dan is yet to tell me the coil pack i need but after that..... its close to running?
to get it running/driving i need to:
1. put oil in gbox, motor, diff, etc
2. fit driveshaft
3. get john (broke) to plumb up some fuel line
4. trigger wheel and sensor made and mounted
5. buy trumpets (not really essential for initial startup)
6. coil pack thing
7. surround the thing with mattress's as it has no brakes!
there is very likely a lot more things to make it happen but this is the big stuff? comment me the shit iv forgotten
and now because
here are some pictures
Ratmat fitted (mostly at this point,all finished now)
some pics of wheel/tyre fitment (phone cam sorry)
175/50 front (stupid high would have to lower 50mm)
175/50 rear (not bad actually)
both 175/50s
rear without tyre fitted
front with 165/65 (looks fine,may change to 175/60)
rear with 165/65 (outrageous and unnessesary stretch)
