heres the project thread for some pics and info http://www.nzdatsun.com/forums/viewtopi ... it=+laurel" onclick="window.open(this.href);return false;
now the main issue is that the reg has lapsed, hence why people call me dereg_leppa
since i got it, i have replaced the engine with another L20et that was running when removed from donor car. radiator has many little holes in it from years of being in the shed. comes with a box of random bits and pieces. has a longnose r200 and cv rear end. diff is not LSD from memory. has super low lovells in the front with some adjustable coilovers in the rear.
did have an intercooler fitted when i got it, be it badly. have since removed and returned to no intercooler just to have it running. it does run, nut it idles really high. could be due to the fact that it had cold water when 1st started, or the fact it has the laurel ecu running a skyline engine
let me know if you are interested by pm or txt.
if no interest, ill keep it locked up till i have time and money to work on it
