Wanting to Buy Springs which will fit in and lower my 1200 Coupe, probably about 50mm will go lower if anyone has anything.
Cheers Ben
0276030303
Datsun 1200 Coupe
Re: Datsun 1200 Coupe
no one makes 50mm lowered springs. They will require shorter shocks + possibly a cert depending how done = therefore cannot buy them off the shelf
- Kitch
yeah thats the problem. you cant get "super-lows" for B110's. only lows, which only drop a pathetic 25-30mm.
The quick tried and true cheap way is what I did with my 120Y, cut down avenger rear springs (I have heard they are about 200 pound spring rate) coupled with replacing the oil in the shocks, and fitted a pipe collar inside to shorten stroke of the shock and ensure the spring remains captive.
I am sure a lot of people have done this upgrade, and got wof's without the need for cert.
- woodies72coupe
Datsun 1200 Coupe
I have a spare pair of avenger springs for sale if you are keen? $50
cheers guys
