help with 1963 bluebird
- Newbie
Re: help with 1963 bluebird
The car runs an E1 1200cc engine, was hoping a gearbox from a 410 might bolt straight up or one from a A12?
I'm not sure if the 410 gearbox will fit. Maybe the guys over at ratsun might know if the J's and E's run the same bellhousing?
The 410 also ran the E1 1200cc. The 411 went to the J13. The gearboxes are different for both, E1 and J13, but could be interchangeable.
I happen to have both sitting in the barn I think. I'll go check soon.
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
- Newbie
Hi, thanks for that, if you have any luck send me a text on
0212710710.
0212710710.
Looks like I may have 2 x J series gearboxes and one E series. I think they are all 4 speed, but the E series may not have had syncro's for going into 1st gear.
The bolt pattern appears to be most the same apart for an extra bolt around the starter motor position on the J series gearboxes. They appear to be the same length, but the J series box has the shifter positioned further back (possibly as they moved away from a bench seat up front).
From memory the spline is the same on the output shaft between the 2, but is different to the A series.
If you want pics or measurements of anything, just let me know exactly what you need.
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
- Newbie
Thanks for that, any chance of been able to come have a look?
Karls 312 has a badge on the grill saying "FULL SYNCHRO"
Yep sure that can be arranged. I'm just up silverdale way so not too far from you.63bluebird wrote:Thanks for that, any chance of been able to come have a look?
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
- Newbie
Great couse im in Dairy Flat, give me a text when time suites you.
