Complete A15 setup for a 1200 ute
Sell stuff
damz721
aka: Damian
Re: Complete A15 setup for a 1200 ute
Post by damz721 »
Keen on carb and manifold, cheers
- 77 B210 S/W
DATY12
Regular
aka: Kev
Post by DATY12 »
I may be keen on the carb and manifold also if Damian doesn't take them.
Whats involved in running a webber?, do you have to convert much, need fuel regulator etc?
Do they make much difference over a standard carb?
Datsuns I've owned
Datsun Sunny x 4
Datsun 1200 Sedan
Datsun 1200 Roadstar Ute
-Current
Datsun C20 Vanette
Kitch
Post by Kitch »
pass on the motor.
talked to my brother and he just going to continue to run the A12 over the summer
its running well, so we figure if it aint broke - dont f$ck with it
Meandatto
Regular
Post by Meandatto »
Kitch wrote:pass on the motor.
Thanks kitch...
Meandatto
Regular
Post by Meandatto »
DATY12 wrote:I may be keen on the carb and manifold also if Damian doesn't take them.
Easy conversion ! All you will need is a new manifold gasket ... It will all bolt straight standard cable will fit on just need to hook the vacuum line up for the dissie job done !! It's been tuned for factory settings I haven't tried to advance the timing on my car to get a bit more or anything, and I'm not running a cam .... But if you do decide to throw a cam in you can tune the carby to suit the cam without changing the jets ...
Quite a noticeable power difference from the standard carby very responsive and revs quite easily to 5000rpm !! Good upgrade but do recommend having extractors with this set up.
Meandatto
Regular
Post by Meandatto »
I picked up a run about last wkend so my ute is off the road !! I still would like to keep the set together so the motor can be test drive ect but won't leave it all together to long long as I need to get into my build ... I will be listing parts on trade me this wk !!
Seedy Al
Post by Seedy Al »
still got cross member????
DATY12
Regular
aka: Kev
Post by DATY12 »
Is the Carb set up still up for grabs or is Damian taking it?
Datsuns I've owned
Datsun Sunny x 4
Datsun 1200 Sedan
-Current
Datsun C20 Vanette
ginga-dato
Datsun Driver
aka: Jordan
Post by ginga-dato »
Has the gearbox been taken yet?
