Removed from an automatic 180B sedan.
Doesnt burn oil or use water.
Has L16 sump fitted to mount in 1600.
Has new manifold and rocker cover gaskets.
Current oil and filter has done less than 5000km (when motor fitted to car), can check records for accuracy.
New clutch and waterpump when fitted less than 5000km old.
L20b Hitachi carb fitted (same specs as Nikki L18), spare carb with new accelerator pump.
$500
Have mint 1600 radiator available for extra, was professionally cleaned internally when motor fitted.
Also a factory 1600 4speed gearbox and driveshaft.
![Image](http://iforce.co.nz/i/xu3exiqo.0to.jpg)
