brake caliper retaining pin clip 180b
Am after one of the wire clips that goes into both brake caliper retaining pins on the 610 models. It is basically a square U shape, with an end each going through the retaining pins. Or do i just get any piece of wire and bend up my own?
Re: brake caliper retaining pin clip 180b
You can use lock wire but it will need tied off, the original wire is spring steal.
