So I was looking at Yahoo Japan and found a listing for traction bar's. Not knowing on what they did I looked in to it more. Has any one used them on there leaf spring rear end?
I have some 5mm thick angle iron and thinking about making my own. Any thoughts?
Tractionbar
- Ivan
- aka: Ivan
Tractionbar
Datsun 260c
- brocky41
- aka: Brocky
Re: Tractionbar
all the ones ive seen a full box section - not angle iron - rubber stops would be easy enough to source
dirtyleppa
- aka: leppa
Re: Tractionbar
I would imagine they would be to stop axle tramp thia increasing traction? I think the only real need for these is if you were doing alot of drag racing or big clutch dumps.
Or if you have massive blocks or reset springs
- brocky41
- aka: Brocky
Re: Tractionbar
Try this - not great for lowering
http://www.hotrodsandhemis.com/Traction.html" onclick="window.open(this.href);return false;
- kobyn
- Datsun Mad
Tractionbar
Yeah they work real well for me as I dump clutch a lot lol
Re: Tractionbar
Unless your getting axle tramp now, you don't need them.
- Ivan
- aka: Ivan
Re: Tractionbar
You may be right Baart, I'll have to get the old girl going to take her out for a spin.
Datsun 260c
Re: Tractionbar
agreed here, just get some 50x50x3 RHS, with some Ubolts n a rubber stop donor, but id do a watts link or similar before even remotely considering these, as they are pretty much drag use onlybrocky41 wrote:all the ones ive seen a full box section - not angle iron - rubber stops would be easy enough to source
