B310 Front suspension to fit 1200
R3spct
Datsun Dreamer
Re: B310 Front suspension to fit 1200
Post by R3spct »
tlssunny wrote:
R3spct wrote:Sometimes i feel that s13 stuff is just as hard to find as B310, i have been keeping an eye out.
why cant you use what you have and just do a simple single pot brake upgrade???? ive seen lots of single pot s14 brakes on tm that are cheap...........
I really dont know what to do, as im trying to avoid a cert, at least straight away, so something bolt on with no adaptors could be cheaper option.
smp has the caliper brackets to fit the n13 calipers and 280zx discs, this is still a good plan atm. I really should get them off him soon...
tlssunny
aka: jesse
Post by tlssunny »
What engine are you planning for this???
what about just using the factory brakes and giving them a wee birthday to start with??? iam running factory brakes in my b310 and they are not great but it aint a race car either, I have just used new everything and iam happy with them
woodies72coupe
Post by woodies72coupe »
I've got 310 struts and brakes on my 1200 coupe. It still has cert for them for some reason!
I am going to put s13 on mine if I can fit them up with my mags as my brakes aren't that flash. Go s13 straight away, save you doing it twice.
R3spct
Datsun Dreamer
Post by R3spct »
tlssunny wrote:What engine are you planning for this???
Engine is a well tickled A15, so its got a fair bit more than stock. Ultimately i might just have to suck up getting a cert, but that means a driveshaft loop and all sorts.
S13 stuff might look close enough to stock for anyone that knows nothing about old datto's.
tlssunny
aka: jesse
Post by tlssunny »
i have a real loved a12/a15 in mine with factory b310 brakes (everything new) and they are fine, why dnt you try that first with the 1200 stuff and they do cert later???
R3spct
Datsun Dreamer
Post by R3spct »
I could try the 1200 stuff, but the calipers had zero movement when i took them off so would need a lot of love to be usable at this stage.
I think i will get some caliper adaptor brackets and n13 pulsar calipers for now, even if i put these on after the 1st wof.
Ive still got to run new brake lines and get a new master cylinder and lines under bonnet atm, rear brakes had new looking cylinders and almost new shoes so hoping they wont need any major work to get going.
