Datto_610
aka: Greg
Post by Datto_610 »
Running SSS oil pressure gauge which works just don't know how accurate it is haha
luke
Datsun Addict
Re: Datto_610's 180B - Cert Prepping!
Post by luke »
im very excited for this car to be legal.....
that, and its fuelling my motovation
1972 1200 coupe KB110
Re:
Datto_610 wrote:Running SSS oil pressure gauge which works just don't know how accurate it is haha
if the gauge is not enough LD 28s (and I am sure others) ran a sensor with gauge and light senders. Just in case you need a light, but want to keep the gauge.
beaver
Datsun Nutter
Post by beaver »
re: check engine light.
If you are running efi and the factory ecu (from doner car) then you need a fault code light/check engine light.
see here http://lvvta.org.nz/documents/standards ... ssions.pdf" onclick="window.open(this.href);return false; see bottom of page 7
Datsunboy will know which pin on the ECU feeds the check engine light.
No biggie to buy a nice LED in a bezel or some such, and hook it up to the ECU.
Datto_610
aka: Greg
Post by Datto_610 »
Don't need it!!! CA18DET's have lights on the ECU itself which indicates a fault so talking to Ian he said this was sufficient
broke
Datsun Addict
aka: John
Post by broke »
Good work Greg!
With those sleeves on the strut.. aren't they already welded on? Or did you just grind off the majority of the spring cup and leave a ring to hold the sleeves up? If you can get away with tacking them on without crack testing the whole assembly then sounds like he's being pretty good about it.
Datto_610
aka: Greg
Post by Datto_610 »
Welded new collar to strut to sit sleeve on thought that would be enough... don't need to get it crack tested again well he didn't mention it..
85_Z31
Datsun Master
Re:
Post by 85_Z31 »
Datto_610 wrote:Welded new collar to strut to sit sleeve on thought that would be enough... don't need to get it crack tested again well he didn't mention it..
usually a welded collar is enough, he might accept a machined sleeve holding the collar in compression so it can't rotate ? doing the same job as some tac welds ?
Datto_610
aka: Greg
Post by Datto_610 »
Possibly but 4(per strut) tack welds would be easier and quicker than making a sleeve also my gland nuts have the hex cut off them so won't work like how you did yours.
So the other day I removed the lock ring for the fuel sender and lo and behold no o-ring!! Took some measurements rang Saeco and picked one up yesterday. One more job ticked off the list! :D
