I have a Datsun nissan sunny coupe with a 1500cc motor , the manifold has a big crack and one of the two studs that holds the flange up has broken away.
I have tried the wreckers and have had no luck .. Does anyone know where i can get a replacement exhaust manifold.
Cheers rossco
sunny B11
Re: sunny B11
Get some branches. Extractors are reasonably easy to make and may be available from coby off the shelf,
Re: sunny B11
Cheers for the reply classicdat
Rang them at coby and they only make extractors for the a12,a14 and a15 engines.
My car is the fwd b11 with the E15 engine. So i either have to learn how to weld or part out this coupe.
There are other B11 sunnys with extractors on the internet so someone must make them.
- Regular
Re: sunny B11
Keep an eye out on the Pickapart stock. I've seen quite a few E powered Sunnys there in the past.
http://www.pickapart.co.nz/stock.asp?yid=4" onclick="window.open(this.href);return false;
Don't part it out! You could get someone to weld the manifold up or make you some extractors quite cheaply.
Re: sunny B11
Thanks Guys
I found a place in Palmerston North that can make them for me .
Seems like they are the only ones in the lower north island that have the skills
needed to get the job done , very helpful and quick to get back to me.
Going up on Monday to get them made and fitted
