Re: 2 doors 1200 2door sedan / engine now in
Can you run a factory bottom hose setup and fitting for the heater hose so you can run them along the strut tower as per original. Just block off the outlet on the bottom hose tube, cut down past the outlet or fit a 1200 one.
dattoboy
Datsun Nutter
aka: Bede
Post by dattoboy »
Awesome work Wal. Those seat retrim in leather/vinyl and it would be bloody hard to tell the difference between them. Great find
2 doors
Post by 2 doors »
classicdat wrote:Can you run a factory bottom hose setup and fitting for the heater hose so you can run them along the strut tower as per original. Just block off the outlet on the bottom hose tube, cut down past the outlet or fit a 1200 one.
Yeah I think that will be the answer .
I got factory hoses off Scotie a year or two back. Not sure if he can do the fitting. But they were reasonably cheap.
broke
Datsun Addict
aka: John
Post by broke »
Awesome work Wal,
What are you doing for engine management? That temp sensor boss looks like a Link one, so I'm presuming either Link Atom or Megasquirt?
2 doors
Post by 2 doors »
Megasquirt
2 doors
Post by 2 doors »
Watching the rugby and got inspired to work on my car , so made a start on the wiring loom scarily I do actually recall what all the wires do , probably be a different story when I do the wires under the dash though.
luke
Datsun Addict
Post by luke »
iv just read this entire thread. lots of work, a very neat car. mine pales in comparison.
1972 1200 coupe KB110
2 doors
Post by 2 doors »
Trying to keep things moving along , I've had the dash frame sand blasted and got some epoxy and gloss black on it today , tomorrow I should be able to put the dash pad back on it, and re assemble the gauges.
Had some real success with the loom tonight , I got the lights and indicators working , dash lights work , but I think I need the voltage regulator plugged in to get the oil and charge light to go , oh and have power coming down the starter wire when I turn the key.
do the wipers go?
I found one of my bulkhead plugs wasn't pushed all the way home.
I had no wipers, no horn, and no charge. (Light wouldn't go out)
The voltage reg will have zero effect on the crank feed to the starter.
