I have fully cleaned these up, etch primed and painted with black zinc paint. Masked the bearing surfaces before painting, soaked in metal rescue to remove as much rust as possible without eating into the metal like an acid etc.
Here is a bunch of pics of what they looked like before painting so you have an idea on the prep that went into it. The splines on the shafts may need cleaning up as they are a bit of a tight fit on the flanges, but I have indexed them where they go in nicely.
I also have the old bearings and spacer tubes which ill include in the sale if you want them. Pretty sure I have the nuts somewhere too but I'll have to do some digging to find them.
Needed for doing CV rear axle conversions in many IRS Datsuns! 1600, 180B, 910 Bluebird etc
Wanting $100 for the lot.
