Michael's 180B Sedan Z18ET
Re: Michael's 180B Sedan Z18ET
- Mikewazowski
- aka: Michael
Okay, got my driveshaft hoop in last night, it just clears
lucky I've got independant suspension so my driveshaft won't move up or down. Also got my seats back in.
Went to put my *new* (second hand) washer bottle in only to find out that it doesn't have the pump on it. Bugger. Oh well will have to find another one.
Will try and get some pics tonight since this page doesn't have any yet
- Mikewazowski
- aka: Michael
Went for a cert last thursday, only need a few things to get it all legal
- two tyres (front right, rear left)
- brackets to hold rear brake hoses
- replace one rear brake hose
- adjust handbrake
- tighten up bolts on r/h rear halfshaft
From memory I think that is it. The cert guy in Rotorua (Dean Longhurst) seemed like a pretty good guy for the record.
Really cool that he was happy with how everything had been put together
Hopefully I can sort this car out over the next couple of weeks and start driving it every day
- adjust handbrake
Sweet, you will be able to bring it down to akaroa!Mikewazowski wrote:Went for a cert last thursday, only need a few things to get it all legal![]()
- adjust handbrake
Really cool that he was happy with how everything had been put together![]()
- Mikewazowski
- aka: Michael
That's the plangingofthesouth wrote:Sweet, you will be able to bring it down to akaroa!
- Mikewazowski
- aka: Michael
- adjust handbrake
- Brackets made, should be welded in tomorrow
- Got hose, will put in after brackets
- Handbrake adjusted
- Bolts tightened
So hopefully should get everything done by the end of the weekend.
Sweet. Pics of finished car courted and on the road!Mikewazowski wrote:- Tyres ordered (should be here Friday)Mikewazowski wrote:
- adjust handbrake
- Bolts tightened
- Mikewazowski
- aka: Michael
Absolutely. Will grab pics in the weekend if it isn't pissing down like it has been lately
- Mikewazowski
- aka: Michael
Got a few pics....forgot to email them to work address >_<
Should have everything done for the cert tonight, and it is going over to Rotorua tomorrow to get re-checked
So now it is just the count down to the Akaroa cruise
I decided to make a list of everything I need to do before then:
- Get cert
- Take engine/gearbox/radiator/etc out and prep and paint engine bay. Then put everything back in again.
- Probably put in my new Brake Master Cylinder, as the old one is looking kinda sad. Must remember to swap the rear check valve across from my old one.
- Sand back a few bubbled areas to investigate rust, also remove from windscreen to investigate and find annoying leak *drip* ... *drip*
- Take to panelbeater's to get rusty bits cut out and new metal put in.
- Take out front struts and rear suspension and lower it a bit.
- Prep and paint exterior.
- Put everything back together.
- Have a beer.
I made up a plan on a wallplanner the other day, and if everything progresses fairly smoothly I should have between 2 - 4 weeks spare before Akaroa after getting all this done. Will probably be a few late nights but should be worth it. Have Alessandra's wagon as back-up transport to Christchurch if for some reason something goes wrong.
- Get cert
- Have a beer.
go hard lad.
