not sure on exact years.....but pre- 1986 ish??? at a Guess.
mostly in the old Omega/Leone body shape
LSD options for your P510 1600 (or similar datsun)
- aka: Dan
Re: LSD options for your P510 1600 (or similar datsun)
As far as I know, they were fitted to some of the late model turbo leones, but were only an option, and are like rocking horse shit. I know a bloke who has wrecked a number of leones, and he's only ever seen one. And he wont sell it to me either.
There was one on trademe a week or two ago that sold for $305.
http://www.trademe.co.nz/Browse/Listing ... =168712678
Actually, that one was an R180
my diffs f##kd well getting their wot kinda lsd could i bolt straight in? 79 sunny b310
A NISMO H150 lsd centre. (Good luck finding one!
I have a used H150 spring loaded locker center. It's a bit worn, But the sidegears are intact. You'd need to fit it to a center with a crownwheel and pinion that were in okay cond. Not quite as good as a proper LSD, but does improve traction though......
- aka: Josh
i no a guy with a screwed leone turbo but its 4wd could i use one of thos diffs ?
Z18ET 1600
- aka: Dan
you can use the rear diff out of one of those
I spoke to the Suby guy I mentioned ealier in this thread. He said the clutch lsd's were only fitted to the turbo leone RX's.
- Dattodevil
- Datsun Addict
- aka: Damo
The 95~ Grandwagon comes out with an LSD rear diff too.
- MONTY
i've got one of those leone diffs in my datto, get it take it to the diff shop get him to tickle with it and you'll be rocking ..... trust me
I'd like to make a correction to what has been said in this thread. the A31's don't have a longnose, so what ever Dans diff came from, it wasn't one of them. ALSO, (at least with my R30) the biggger cool looking finned late model rear cover, won't fit unless you either, drill and tap the bolt holes to 10mm. (From 8mm) Or make some adapter sleeves to adapt the 8mm rear cover bolts to the 10mm rear cover bolt holes.
