Page 2 of 2
Re: Sticking throtle
Posted: Sat Jun 05, 2010 11:26 am
by torqued
nosebleed wrote:check your return springs aswell..
is your cable frayed in anyway?
what did you use to lube it? you should be using a "dry" lube
post a pic of your linkage to the throttle
Posted: Sun Jun 06, 2010 4:14 pm
by TL Speed Shop
Thanks every one for your input. It is definatly not the cable as this runs as free as a bird. The carbie is the problem I think. It is not the best one in the world, but its the best I have. I will at some stage get a rebuld kit and put it in my other carb. I think its more to do with icing up and semi worn out, as the car does not always idle when the engine says its running temp.
Thanks,
Simon.
