-Black 1973 datsun 1600, fully panel and painted in 2k a few years ago.
-SSS replica, Full SSS dash with tach - these tachos regularly crap out as this one did, but I've had it repaired by an instrument shop who used the same face and put a new electronic unit behind the scenes. Black SSS door trims, SSS badges and rear vents, SSS grill, comes with original SSS rear seat which is pretty much the same as a standard 1600 rear seat.
-Black interior, headlining, carpet. Evo 1 recaro seats on original 1600 rails. comes with matching evo rear seat but not customized to fit yet.
-Momo steering wheel
-Glowing eyes skull gearknob!
-Fully re-wired from front to rear by myself, I am an auto electrician so i did it properly and in a trick manor which makes it very hard to steal. Has battery in boot and battery master switch bolted to the tunnel by the clutch pedel. Custom interior fuse box. RCA cables run to amp in rear and speaker wiring through out car.
-Blaupunkt 600 watt amp, cant recall what sort but she's awesome.
-Dynatron alarm with battery back up siren. 4door central locking - alarm and central locking work even if battery master switch is off - making the vehicle very hard to steal.
-Semi sealed headlights with aircraft landing lights as second set of high beams.
-White advanti sa15 17x7inch rims with 205/40 profile tires all round
Engine/driveline
-Microtech ltx8 ecu, runs 4 bosch coils, electronic boost control through ecu, comes with 4line hand controller.
-S12 silvia FJ20ET and 5 speed,
-Series 5 Rx7 injectors 550cc
-Remote oil filter mount.
-Polished intake manifold and rocker cover
-Falcon XF throttle body.
-Big t04b turbo on custom top mount exhaust manifold, turbo excess external waste gate.
Dytech oil catch can
-3" exhaust front to rear going into dytech racing stainless dump muffler.
-R200 4.44 clutch lsd with maddat moustach bar, c.v. joint conversion. driveshaft length modified to suit 5 speed box and diff flange.
-Wallbro fuel pump
-under car 1 liter surge tank
-half inch fuel lines
-Rx7 batmobile aluminium race radiator, with twin lowprofile 9" fans
-Front mount intercooler
-Bov
Suspension and brakes.
-Fully rebuilt front end, powder coated and rebushed. Reversed front x-member
-Rebuilt steering box with box brace
-Custom R31 skyline coil over struts with adjustable koni sport inserts and 200pound coil over springs
-50mm bump steer spacers
-Camber plates
-Adjustable caster arms
-20mm swaybar
-R32 GTR front brakes and rotors.
-280z master cylinder
-Custom rear springs
-Short rear adjustable koni sport shocks to keep springs captive.
-Custom fully rebuilt rear end, powder coated and rebushed - Modified to allow large exhaust, and adjustable camber and toe-in.
-R31 turbo IRS rear disks, with mitsubishi starion calipers, uses the caliper as the handbrake, custom handbrake cables.
To anyone that has emailed me and semi expressed interest; you know who you yall are.... if you are serious you better get in contact with me this weekend because im going to put it on tardeme on sunday night/monday, but i would rather sell it to someone who is involved in the datsun community. plus i hate the thought of spending $30 ripoff dollars on tardme grrr haha
