Re: WTB or Swap Input shafts
Posted: Fri Mar 11, 2011 5:38 pm
The Difference may be that these 5x1 input shafts came from a Z32 Non turbo and not the typical R32/S13/other common Nissan stuff
I hope the rest of it's going well and you get it sorted soon.
EDIT >
after reading through this http://forums.hybridz.org/index.php/top ... o-and-why/" onclick="window.open(this.href);return false;
It sounds as through some R200's had larger diameter input shafts that kept the same number of splines.
From my reading it sounds that 5x1 input shafts had the smaller 30 spline axles and that 6x1 input shafts had the larger 30 spline axles.
I have no idea about the 3x2 input shafts but is it possible somebody is confusing R180 input 3x2 shafts with R200 3x2 input shafts ?
Greg if you get desperate and DO have to unbuild your axles and swap CV's end over I can supply you with the 5x1 CV ends in exchange for you 3x2 CV ends to give you a matched set.
but like you say it would be mega hassle.
EDIT >
