Page 2 of 3
Re: Sunny B310 Project
Posted: Fri May 27, 2011 11:56 am
by LilMan
Need a workshop manual anyone got 1?
Posted: Tue Jun 07, 2011 7:27 pm
by LilMan
went to take it in for a warrant having put in original springs and raising it to original height and it failed on:
Rust at L/H c pilar area
Blake fluid low
Windscreen washers dont work
R/F door hinges worn
Rear foot brake imbalance
Handbrake doesnt hold on to both wheels
High stop light repositioned
Drivers seat moves
Passanger seat moves
Worn L/H lower (something cant read) suspension ball joint.
Can anyone help with some of these parts?
Ideas?
Posted: Tue Jun 07, 2011 7:49 pm
by Datto
take out the highstop not needed cars to old to old to require one anyway
and youll probably find that your rear brake shoes are leaking and fluid has
gone all over the shoes which is why one side isnt woking well and handbrake
dosent work. so new shoes and wheel cyclinders and drum skim or just clean out
as well as you can. pretty easy fix
lower boint should be a piece of piss
and everything else just looks like simple shit except maybe the rust?
Posted: Tue Jun 07, 2011 11:30 pm
by DAT620
Rust at L/H c pilar area- fix or have fixed
Windscreen washers dont work- take them off not required by vehicles manufactured before or
on January 1st 1992
Blake fluid low - all of these wll be related rekit the rear brakes, with new cylinders and shoes (even if the shoes arent warn, if they have been wet with brake fluid they'll be munted anyway, new drums optional- when you pick up the brake parts they can tell you the condition of the drums and if they need to be replaced)
High stop light repositioned -take off, vehicles pre 1990 dont require them
Drivers seat moves check mounting bolts are tight
Passanger seat moves as above
Worn L/H lower (something cant read) suspension ball joint. replace
too bad youur not in CHCH otherwise Id come and help you out.
Posted: Mon Jun 20, 2011 9:41 am
by LilMan
Pink sticker is off. :thumbsup:
Now its for sale. Offers?
Posted: Mon Jun 20, 2011 6:03 pm
by Rusty
giving up already?
I wouldn't I gave up too early on my datsun projects and Im regretting it now 3 or 4 years down the track.
Posted: Mon Jun 20, 2011 7:34 pm
by LilMan
How can i get it to a good height without spending heaps though..
Posted: Mon Jun 20, 2011 10:12 pm
by fast4motion
How low do you want it?
Posted: Tue Jun 21, 2011 5:39 pm
by LilMan
100-130mm something like that.
Posted: Tue Jun 21, 2011 7:36 pm
by fast4motion
What size wheels and tyres do you have fitted?
