Page 2 of 3
Re: WTB ca18de headers and carb manifold for carb setup
Posted: Sun Jul 31, 2011 9:52 pm
by nick_m
its pretty close side draft is 90mm boire spacing CA is pretty close to that, can't recall off the top of my head
Thats all the one that brock sold was anyway. Pretty sure josh has/had a proper cast one.
Posted: Sat Aug 06, 2011 2:18 pm
by datso
Yes the oval holes are very close to a weber spacing.
Theres alot of work involved hence prefer the mani already done.
However It wont matter as I have another idea which is doing
the same but instead of weber flanges just 4 tubes welded on
after machining off the factory flange that meets the upper
manifold flange. This will allow my cbr1000 quad carbs to fit.
Re: WTB 4 port ca18de head
Posted: Sun Apr 22, 2012 8:24 pm
by datso
any 4 port heads out there?
Posted: Sun May 06, 2012 6:01 pm
by datso
still looking
Posted: Sun May 06, 2012 8:47 pm
Keep an eye on
http://www.trademe.co.nz" onclick="window.open(this.href);return false;
They pop up there from time to time.
Posted: Mon May 07, 2012 10:18 pm
by datso
will do Bart, if you see any that come up and I miss it pls let me know
Should just fit 42mm inlet valves like yours, get 79mm bores, an autorotor fed by a 2inch SU and be done with it
Posted: Tue May 08, 2012 7:09 pm
TBH, I don't really know if the 42mm valves are worth the hassle first up. (Mine were already fitted to the head when I bought it) Just build a stout bottom end, blower friendly cam, and do skids. You can always add a high performance head later on down the track.
Posted: Sat May 12, 2012 1:04 am
by datso
sounds like you got your head in the right place
surprising with all the spirits you have!
Posted: Fri May 25, 2012 2:32 pm
by datso
looking but no score yet
Posted: Sun Jun 24, 2012 9:16 pm
by datso
