lowest 1200 sedan??
Re: lowest 1200 sedan??
because of your brakes?
Yea 14"s rub on the rear calipers
Datsun 1200 DAILY THRASHER Sedan
A14 Race engine, 48mm Twin Webbers, Gilmer drive, 5 Speed, Scorpion Lsd diff, 4 Wheel Disk Brakes and a full leather retrim..
1967 Ford GT Cortina SHOW CAR
rebulit to factory specs everything..
crustywhip
- Datsun Addict
- aka: Kane
What sort of rules do you have in oz regarding vehicle mods? I have seen police defecting cars with pod filters and height on shows we see here. If the smallest wheel you can run is a 15 then you need to run the lowest profile tire.
grind the calipers down a bit?
The rules here are bullshit every little modification can be classed as a defect right down to head unit anything non standard is a defect and very strict engineering criteria
