looking more and more like a car
160jsss
Re: bits
Post by 160jsss »
As soon as I can work out how to put vids on I'll put some on moved under it's own power to day Brake's windows and seats are so over rated
Violet - ??????
160jsss
Re: bits
Post by 160jsss »
after first drive back in the shed
http://www.youtube.com/watch?v=Iab3SEw9tBA" onclick="window.open(this.href);return false;
and first start in 12 years
http://www.youtube.com/user/datsun160js ... q3dxOmQUsg" onclick="window.open(this.href);return false;
Violet - ??????
Re: bits
Stoked, sounds good, even idles!!
aka: leppa
Re: bits
Post by dirtyleppa »
nice :highfive:
160jsss
Re: looking more and more like a car
Post by 160jsss »
started Phosphoric acid washing the car today using 3M stuff going well photos are crap .
Violet - ??????
160jsss
Post by 160jsss »
One more step towards a WOF just did the brakes all new slaves shoes and my spare drums as the one's on it where so thin.
Blew all the lines out and cleaned out the master all new fluid running through peddle is now hard as a rock.
Still have not sorted out the lights but will run solenoids was going to use 4 one for each light but think that will be over kill will look at replace the sealed beams with H2 style replaceable bulbs .I need good lights as I work a lot of nights and it's about 70ks round trip
Violet - ??????
Josh
aka: SeEn-ThE_lIgHt
Post by Josh »
Wicked!
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
160jsss
Post by 160jsss »
Yes Yes got the head lights working started at the relay when it gets a pulse of power it switches between high and low beam ,after a clean up I got it working on the bench but not in the f@#king car .
Worked my way back to the high low beam switch it was just a bit loose as i moved it i heard the relay click happy days says I :burnout:
Time to go nuts with the contact cleaner and we cooking with gas .
Next job is to hook up some power relays to stop voltage drop .
Things left to do before WOF last bit of rust to cut and weld hook up the heater etch prime and then high fill primer both will be 2pak then its glass back in it will not get painted till I get the bum and engine bay sandblasted i hope in the xmas break top will get a sand down and paint sort of BRG same as it was before
Violet - ??????
160jsss
Post by 160jsss »
Finally Wheels
Violet - ??????
160jsss
Post by 160jsss »
Man long time since I've done anything on the J put some gas in it tonight started as soon as the gas hit the carbs Man that feels so good
Violet - ??????
