13x7 tyres/clearance issue.
Re: 13x7 tyres/clearance issue.
I run Std Tridents on my 1200, 13x6, with Balloony 185/70 13s they rubbed too much on the rear, I'm guessing you will have issues with 7s, 1200s are pretty tight fit to the rear.
braasmonkey
Site Admin
aka: Braasy
Post by braasmonkey »
I'm running 14x6 rims with +15 offset on my 1200 I believe (will have to sift through my build thread to confirm). They have balloony tyres on them too (185/55) and rubbed. Rear guards had to be rolled and flared a tad to make them fit. The front wheels had to be pulled forward as they were rubbing on the chassis. The front guards were rolled and flared to match the rear. Also, the stock brake callipers touched the inside of the rim, so had to give them a wee lick too.
- Braasy
z181200
Datsun Mad
Post by z181200 »
Common theme coming through here. Ballons fail and require guardwork.
185/55 aren't that Balloony and 15s on a 1200, you'd need narrow rubberbands not to have the same profile, just not much room. Keep us informed as to how they go Luke. All the best. My tyres can fowl the front guards on lock if I hit a bump, eg entering a drive way at speed.
braasmonkey
Site Admin
aka: Braasy
classicdat wrote:185/55 aren't that Balloony and 15s on a 1200, you'd need narrow rubberbands not to have the same profile, just not much room. Keep us informed as to how they go Luke. All the best. My tyres can fowl the front guards on lock if I hit a bump, eg entering a drive way at speed.
They're balloony to me! lol I'd have gone 13x6 if I knew some guard work was required and hadn't already purchased the wheels (with tyres).
2 doors
Post by 2 doors »
its not a major job to mini tub the rear on one of these :badgrin:
dattoboy
aka: Bede
Post by dattoboy »
coupes have slightly wider guards than a sedan on the rear.
i run 165 60 13s on a 7" rim no probs on the back.
same tyre on a 6.5" rim on the front.
luke
Post by luke »
wheels arrived last night! and they fit in rear guards!!
the birds eye view pic was taken on a lean so you could actually see the edge of the rim. might be inside the guards by 5mm? LUCKY!
1972 1200 coupe KB110
