Removed the intercooler & piping, the piping is steel and was starting to rust inside and out, bits of it were crushed and bent too
Removed the inlet piping for the turbo, air flow meter and air filter box
Removed the charcoal canister and related piping
Removed the engine brace, the bush in it was rooted and I needed the room
Started cleaning down the front of the motor, it's going to be a big job getting rid of all the oil/grease
Fixed one side of the front bumper which was loose
I had a whole bunch of ali pipe, silicone bends and a K&N from the old R30 and piping I used to have on the Z so I have temporarily come up with this:
Until I can get one of these:
I'm planning on running the piping over the top so the brackets are going to be on the wrong side.
I also fitted the rest of the wheels, the back ones are just outside the guards and the front ones are out a little bit further than that. Took it for a quick drive and after giving it a little bit of stick it decided it didn't want to run, got out and got a hand pushing it from some random dude towing a Starlet around my neighbourhood. Turns out I'd popped one of the pipes off, I really need to get a more accurate boost gauge and see what boost it's making as it feels a lot faster than it should be. The wastegate line has been cut previously and has a bit of brake line or something in it but other than that I can't see any reason why.
