84 200zx turbo info required
DJZ
Re: 84 200zx turbo info required
Post by DJZ »
That's a very good idea. There was factory recall on the Z31's not long after they came out because of leaky injectors. I had a look at one a few years ago, you couldn't recognize anything in the engine bay due to the fire.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
southerndatsun
Regular
Post by southerndatsun »
i would say it would get pritty toasted under there.i have a 89 vg20e motor in shed with a intake manifold with Oring side feed fuel injectors and rails.was going to pop in some rb25det injectors in it at same time and make it a upgrade at same time.
85_Z31
Post by 85_Z31 »
I had no end of trouble with stock leaky injectors.
I got rid of the lot and started again with some RB injectors
southerndatsun
Regular
yeah i only got one problem with it atm.i have low impedance injectors in it now but the rb25det ones are high impedance not to sure it i have to run resistors with them ou not.
85_Z31
Post by 85_Z31 »
Early RB26DETT 440 or 444 cc/min injectors are low impedance.
But by changing the size of the injectors you will need to fit Nistune to your stock ecu , or lower the fuel pressure so that your injectors are flowing the same amount of fuel.
I believe GTIR pulsar 440 or 444cc injectors are the same as the RB26 ones.
I shold have stated specially that i used the early 89 style gtr injectors
DJZ
Post by DJZ »
All GTRs have the same size/impedance injectors which is one of the quirks of the RB26 and yeap GTiRs also have the same ones in them.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
datsunboy
aka: Dan
Post by datsunboy »
You won't need to install nistune. But you will need to at last re chip you're ecu......much chapter than nistune.
southerndatsun
Regular
ok.what was the price to do the nistune? i am quite familiar with the link g4storm setups as i have instaled one in my mk2 cortina running a sr20det. the power potential of the vg20 i reacon would be quite low compaird to a 30et or a vg33et.
datsunboy
aka: Dan
Post by datsunboy »
Check out their website, I think it's around $500
southerndatsun
Regular
ok that not too bad a bit cheaper than 16hundy to do about the same job as the link.also noticed today my turbo on it.has spewing oil out somewhere joys of owning a older datsun time to have a look see
