its got an NA rocker cover and oil pump from those pics.
my DR30 RS ('83) had an R180 clutch LSD in it. only one ive seen, and had real oddball halfshafts too.
body tag should tell you. transaxle will be RC39 (R200 3.9 FJ turbo)or RC41 (R200 4.1 FJ NA) if its still got the original one in there...
Another project? R30 rs
Re: Another project? R30 rs
Looks like you got the bug mate.
- Evil13
- aka: kane
Haha yea I can't help myselfBartman wrote:Looks like you got the bug mate.
1200 sedan
1961 ford galaxie
1961 ford galaxie
- Evil13
- aka: kane
Says rb41vegie wrote:its got an NA rocker cover and oil pump from those pics.
1200 sedan
1961 ford galaxie
1961 ford galaxie
awesome - you need my wagon and that hatch wag on tm for the 4 models haha
- Evil13
- aka: kane
right i started going thru the car its so cool the coupe but silvia and dato 1200 only holds 2 people so another coupe isnt really any good for the family so thinking put all the rs stuff in sedan and make a rs sedan so i need abit of help what do i need to change and ill sell the rest
wiring loom and ecu
engine and gbox
it isnt a lsd but it has disc brakes and a rear swaybar so fit all that
electric fuelpump
crossmember
do i need to change fuel tank?
what else should i fit honey comb front on it and rs badges
i currently have a ld28 auto gt
also got these 2 gearboxs think the long one is fl20 but is the other a stumpy l series?
wiring loom and ecu
engine and gbox
electric fuelpump
crossmember
1200 sedan
1961 ford galaxie
1961 ford galaxie
LH one looks like an LD28 or LD20 gearbox - is it a five speed?? if you look closely the belhousing is turned slightly (follow the top casting line from box end to bell housing) as the LD or L ( cant remember which one ) is leaned over more.
You can convert your auto over
therefore is most likely a 4.1 R180 like mine was.Evil13 wrote:Says rb41vegie wrote:its got an NA rocker cover and oil pump from those pics.
and right hand gearbox looks to be a FJ20 NA box. it has the small flat bit at the top of bellhousing.
man i forgot how kooky those long offset gearsticks were
- Evil13
- aka: kane
i want your fender mirrors on your wagon so coolbrocky41 wrote:awesome - you need my wagon and that hatch wag on tm for the 4 models haha
1200 sedan
1961 ford galaxie
1961 ford galaxie
I would say LH gearbox is off a L20ET or other non tilted L series, which would only be a 6 cyl. Is it dogleg or H pattern? You can identify them fairly easily when they're clean, they will have 71B or 63A on the casting on the bell housing usually. You can use a gearbox with the wrong tilt for your engine without a problem, you just have to bend the gearstick (easy) or just deal with the slant (also easy)
