Page 2 of 4
Re: Another project? R30 rs
Posted: Thu Feb 21, 2013 6:03 pm
by vegie
its got an NA rocker cover and oil pump from those pics.
my DR30 RS ('83) had an R180 clutch LSD in it. only one ive seen, and had real oddball halfshafts too.
body tag should tell you. transaxle will be RC39 (R200 3.9 FJ turbo)or RC41 (R200 4.1 FJ NA) if its still got the original one in there...
Posted: Thu Feb 21, 2013 6:49 pm
Looks like you got the bug mate.
Posted: Thu Feb 21, 2013 7:41 pm
by Evil13
Bartman wrote:Looks like you got the bug mate.
Haha yea I can't help myself
Posted: Thu Feb 21, 2013 7:43 pm
by Evil13
vegie wrote:its got an NA rocker cover and oil pump from those pics.
Says rb41
Posted: Thu Feb 21, 2013 8:39 pm
by brocky41
awesome - you need my wagon and that hatch wag on tm for the 4 models haha
Posted: Thu Feb 21, 2013 8:43 pm
by Evil13
right i started going thru the car its so cool the coupe but silvia and dato 1200 only holds 2 people so another coupe isnt really any good for the family so thinking put all the rs stuff in sedan and make a rs sedan so i need abit of help what do i need to change and ill sell the rest
wiring loom and ecu
engine and gbox
it isnt a lsd but it has disc brakes and a rear swaybar so fit all that
electric fuelpump
crossmember
do i need to change fuel tank?
what else should i fit honey comb front on it and rs badges
i currently have a ld28 auto gt
also got these 2 gearboxs think the long one is fl20 but is the other a stumpy l series?
Posted: Thu Feb 21, 2013 8:52 pm
by brocky41
LH one looks like an LD28 or LD20 gearbox - is it a five speed?? if you look closely the belhousing is turned slightly (follow the top casting line from box end to bell housing) as the LD or L ( cant remember which one ) is leaned over more.
You can convert your auto over
Posted: Thu Feb 21, 2013 9:37 pm
by vegie
Evil13 wrote:vegie wrote:its got an NA rocker cover and oil pump from those pics.
Says rb41
therefore is most likely a 4.1 R180 like mine was.
and right hand gearbox looks to be a FJ20 NA box. it has the small flat bit at the top of bellhousing.
man i forgot how kooky those long offset gearsticks were
Posted: Sat Feb 23, 2013 8:58 am
by Evil13
brocky41 wrote:awesome - you need my wagon and that hatch wag on tm for the 4 models haha
i want your fender mirrors on your wagon so cool
Posted: Sun Feb 24, 2013 2:36 am
by broke
I would say LH gearbox is off a L20ET or other non tilted L series, which would only be a 6 cyl. Is it dogleg or H pattern? You can identify them fairly easily when they're clean, they will have 71B or 63A on the casting on the bell housing usually. You can use a gearbox with the wrong tilt for your engine without a problem, you just have to bend the gearstick (easy) or just deal with the slant (also easy)
