Monty's 180b
Re: Monty's 180b
Lots more time for working on the datsun then!
- MONTY
Re: Monty's 180b
exactly
- MONTY
Re: Monty's 180b
ok so i just realised she took the camera god damn
Re: Monty's 180b
Lol yeah the camera i used to have was hers so, looks like i need my own too.
- MONTY
Re: Monty's 180b
ok so if i cant put the photo's up here's some details
Engine
s15 sr20de 110kms
s14ecu(so i can use my datascan tool on it)
cold air box
oil cooler added
Driveline
s14 k's 5 speed
original auto d/shaft
subaru leone plate type lsd also tickled by the diff shop
standard uj axles
5 puk h/d clutch
wilwood clutch cylinder and new lines
Brakes
all new lines, gtst master cylinder
wilwood bias controller
front
r31 non turbo struts with rx7 4 pots
250lb springs new inserts
pegeout 306 dics 295mm
rear:
hydraulic handbrake and the original
r30 rear subframe and discs fitted
r30 shocks (i rekon i can get some s13 adj's in the back just can't afford it
200lb springs and all lowered a wee bit too
exterior
crap at the moment will be painted white again one day
ugraded to semi sealed lamps and aircraft landing light for my high beams
the most important thing the lourve
towbar!!
mud flaps removed
and some ok 15 with no dish but no money to change
fuel
-8 lines
bosch 910 pump
carter low pres pump
aeroteck fuel filter
surge tank etc
Interior
sss dash
elcipise h/u
new parcel tray made
two v10 sti seats
racetech 1000 seat for racing
wild cat steering wheel
and it still looks like a shitty old datto perfect
Engine
s15 sr20de 110kms
cold air box
oil cooler added
Driveline
s14 k's 5 speed
standard uj axles
5 puk h/d clutch
Brakes
front
rear:
exterior
towbar!!
mud flaps removed
fuel
-8 lines
bosch 910 pump
surge tank etc
Interior
sss dash
elcipise h/u
two v10 sti seats
- MONTY
Re: Monty's 180b
ok just a wee update until i get a camera
have removed seats and put car back up on stands
finsihed the clutch line and resovour so now the bonnet closes
just about to remove the old seat runners and make up new frame
wiring is now 99% complete
hyd handbrake removed for now
na throttle body fitted finally
front struts out to be modified
- MONTY
Re: Monty's 180b
ok got my new brake calliper mounts back for the 3rd time i had a "really fussy" engineer made these up the first time, so much for fussy look at the huge slot which caused the calliper to fall onto the dis! imagine if this happened down the back straight of ruapuna god i'd hate to think what would happen.
so anyway i had a guy at work make some up (the top ones) and wow what a difference
and then a photo of the completed strut!
so just get these seats mounted and i'll be out driving again!!!!!
oh i did notice too the other day my park lights come on when i brake god damn stupid wiring!!!
Re: Monty's 180b
Hey Lee... you know how your really awesome and stuff... do you reckon i could get the dimensions for those caliper brackets?? May be going the rx7 4 pot direction also.
Re: Monty's 180b
lookn good man
- MONTY
Re: Monty's 180b
hey gregg your more than welcome to sus out those brackets but i need to put them on the mill first, should have them done in the next few weeks then i'll give them to ya, you'll have to run the same discs and struts tho
