Page 2 of 2
Re: Can you fit a r33 gtr gauge cluster to a datsun??
Posted: Thu Mar 06, 2014 4:38 pm
by Maxz546
classicdat wrote:Supercheap. Or Get your datsun club repco card and go for it at repco.
Thanks. Thats right calibre do a black gauge that looks really similar. I wonder if they do a speedo. To google
Posted: Thu Mar 06, 2014 5:53 pm
by Maxz546
Ok random questions as ive been looking into this. What gauges work without a ecu??
Posted: Thu Mar 06, 2014 8:55 pm
by beaver
It depends on the gauge and what type of sender it needs. there is no one answer.
eg you can get mechanical speedos (which run off a gearbox speedo drive) or some spedos run of an electrial signal.
Posted: Fri Mar 07, 2014 1:01 pm
by Maxz546
Ok i guess it will be best to see if i have mechanical or electrical then go from there. Thanks
beaver wrote:It depends on the gauge and what type of sender it needs. there is no one answer.
Posted: Fri Mar 07, 2014 1:11 pm
by beaver
your speedo will be mechanical, tacho will be electric (runs off the coil), all others will be electrical (ie they have their own sensors)
If you want to fit a new speedo you will have a tough job making it read properly (you will either need to calibrate to work using your existing speedo drive, or if you get an electric one you will need to somehow install a speed sensor).
Replacement tacho is easy, same for water temp + oil pressure (as long as you use the senders that come with the gauges).
Keep the original gauges. much simpler and it wont look stupid.
Also get your car won the road before worrying about useless shit like this.
Posted: Fri Mar 07, 2014 1:13 pm
by Maxz546
Mine is part original and part not. But i want to get gauges that look originalish but are nice like this one...
beaver wrote:your speedo will be mechanical.
If you want to fit a new one you will have a tough job making it read properly.
Keep it all original.
