L28 flywheel to take the 240mm clutch
- Datsun Mad
Re: L28 flywheel to take the 240mm clutch
You could just get Neil at auto clutch to build you a clutch. It wont break then and take 3 times the abuse a 240mm stock off the shelf item will.
thanks for the info guys. I wanted it for last weekend so ended up getting a four puk ceramic with HD pressure plate from RPM to fit the 225 it feels way better than the old one and isnt slipping so fingers crossed it'll last longer than the last.
71 240Z
78 810SSS
78 810SSS
That should be sweet for what you're doing.
