Hey, yea they replace the outter and inner and the adjuster.
I haven't fitted them yet as i need to try locate a drag link and idler arm.
I can take pics of them in hand if you want?
Suspension arms
Re: Suspension arms
datsunboy
- aka: Dan
They don't replace your steering linkage between the front wheels. Only the tie rods.
You will need to have your mounts drilled out to suit as the ball joints are larger than stock
unlimitedpower
- Datsun Mad
Re: Suspension arms
I'll prob keep the stock ones at this stage as its only a road car and there should be enough adjustment in the factory setup to do the job there,
Its the other arms and some camber plates that i think will really make the most difference
Have you fitted all yours up yet Dan? Would love to see a photo of it all on the car.
datsunboy
- aka: Dan
Na not yet, just gotta get the rear end sorted so we can lift the front up and do that
