Page 2 of 6
Re: L28 blow through tubo.
Posted: Sat Apr 08, 2017 2:39 pm
by gman
The main differences are in getting them to seal under boost and in getting the carbs to equal the boost fast enough and the way OER and HKS have dune it the carbs get up to boost presser before the runners.All the gasket faces have a raised ring around them to stop the gaskets from being pushed out under boost o rings on every thing fuel level and exsalrator pump all adjusts from out side at the top so you don't have to rip them apart to make fine adjustments . Floats are solid so they don't crush and the fuel float bowl and needle bowl have there own presser equalizing source .
Posted: Sat Apr 08, 2017 3:19 pm
by mitey1200
Aw good to know. I bought some turbo gasket kits and dellorto top hats off eBay and seem to be holding up. Only 9psi at the moment but no dramas yet.
What boost are you planning on running?
Posted: Sat Apr 08, 2017 4:29 pm
by gman
Well my son is going to race this one so it will go out on 10psi then 16psi if we have to.
Posted: Tue Apr 11, 2017 4:40 pm
by gman
I got time to do weld the wastgate flange on today came up alright
Posted: Tue Apr 11, 2017 6:41 pm
Very nice!
Posted: Tue Apr 11, 2017 7:17 pm
Holy crap, that's beutifull .
Posted: Tue Apr 11, 2017 8:58 pm
by b110sss
One word, wow!
Posted: Wed Apr 12, 2017 4:00 pm
by gman
Turbo and wastgate all back together.
Posted: Sat Apr 15, 2017 4:21 pm
by gman
Bolted up turbo and wastgate along with plenum to make shore the clearances are all good . Just a 20mm spacer between the manifold and tubo needed.
Posted: Sun Apr 16, 2017 8:18 am
Thats awesome
