Fuel pump recommendations
Re: Fuel pump recommendations
Yeah I'll be running a surge tank at some stage as around 1/4 tank I get fuel surge round corners in my intank set up.
- gman
- aka: gman
in tank surge tank still runs two pumps one to fill it and one to feed the carbs or whatever. If it runs one pump it will be a catch/ splash tank a completely different thing.broke wrote:Cheers guys, in-tank is quite appealing as it's omly pne pump, one relay, one set of plumbing etc, however I'm still pretty keen on a surge tank having heard of some other people's bad experiences with in-tank
Might look and see what those Nismo ones are going for (I could swear they're the same as a 260C pump) compared to the Carter - I remember quite liking the "bong-smoking" noise they make![]()
And yeah that pump in the 120Y seemed like a good one, for some reason I had it in my head that VL's were in-tank 040's? Seems like if you want a huge fuel pump or injectors you're spoilt for choice nowadays, it's the smaller stuff that's harder to get!
i went an intank setup for tidyness (GA16DE route) and used a non expensive and common as fuck rb20e pump out of a cefiro. nick murchison did the work and wal sillflossed it afterwards..... i think. i remember wanting any old pump as long as it was easy to get again for cheap availability should i fuck it somehow.
It just had a plate welded overtop to suit new mounting screws and a few baffles inside tacked in to prevent surge.
remember though i never fitted it so cant say wether it was quiet etc. i went in tank to reduce possible noise anyway. welcome to look over it to see if you like the way it was done etc
1972 1200 coupe KB110
VL's run a lift pump and the external.broke wrote:Cheers guys, in-tank is quite appealing as it's omly pne pump, one relay, one set of plumbing etc, however I'm still pretty keen on a surge tank having heard of some other people's bad experiences with in-tank
