Page 11 of 11
Re: 910 Wagon Project
Posted: Thu Nov 17, 2011 10:19 pm
by mindgem
i dont have a compressor, but i do have a vacuum bleeder thingy but i dont trust it as much as the normal method. do you think if i just bleed the heck out of the system it will eventually get better than what it is?
Posted: Thu Nov 17, 2011 10:37 pm
You can bleed the master at the pipe nuts if you want, that can help, just messy, watch your paint.
HAve you touched the rear brakes? What is their adjustment like?
Posted: Thu Nov 17, 2011 10:43 pm
by mindgem
havent adjusted them since when i put the new wheel cylinders in, but i wouldnt have thought they would have changed much since i havent been driving it but i could be very wrong.
Posted: Thu Nov 17, 2011 10:50 pm
Does the pedal pump up to a full pedal and hold pressure?
Posted: Thu Nov 17, 2011 11:00 pm
by mindgem
it builds up a little and falls when i start the engine but i wouldnt say it builds up to a proper pressure because its still quite easy to get it to the floor. the manifold vacuum to the booster is good but havent looked at the check valve
