Without a hoist it's a massive biatch.
Only advice I can offer is instead of using a pipe bender to do the bends, use a 2inch ID or there abouts round piece of pipe to pull the fuel line around to make the 90's.
Roughly the strut tube size, so much easy than a cheap pipe bender, I did the same with some brake lines.
That tank looks sweet.
Nick 1200 sedan Race car - Shit this things needs finishing
Godzilladat
nick_m
Re: Nick 1200 sedan
Well today I finished dressing a shitload of welds in the boot and removing the old fuel tank mounts from the strut towers, I also added some more welds to the frame now that the sheet metal is finished and a couple of welds to the angle mounts on the tank.
And just finished putting a single coat of POR 15 on the inside and underneath of the boot floor, It looks a million times better. Will have to get some more POR 15 and do another coat or two though before its ready for seam sealing.
nick_m
Re: Nick 1200 sedan
Da da
Re: Nick 1200 sedan
- Josh
- aka: SeEn-ThE_lIgHt
Re: Nick 1200 sedan
Top notch Nick, thats a nice setup.
damn, T-Bolt clamps are sexual
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
- Dattodevil
- Datsun Addict
- aka: Damo
Re: Nick 1200 sedan
that looks mint! You could probably just use butyl mastic (window sealant) to seal the tank in.
Re: Nick 1200 sedan
boot looks puurrty
nick_m
Re: Nick 1200 sedan
to seal what part, do you mean between the fuel pump and tank?Dattodevil wrote:that looks mint! You could probably just use butyl mastic (window sealant) to seal the tank in.
nick_m
Re: Nick 1200 sedan
Yup and expensive! But ultimately worth it because I'm fussy and like things too look niceSeEn-ThE_lIgHt wrote:Top notch Nick, thats a nice setup.
- Josh
Re: Nick 1200 sedan
Me too, me too.
Thats why these damn things take so long to eventually finish
