Page 110 of 125
Posted: Sat Jan 14, 2017 10:35 pm
Been driving this on the semi reg and has been pretty good! Definitely fun! Still got the same 3rd and 5th gear popping issues but other than that no other issues! Until today....
Went to a mates place this afternoon was about to do a u turn turn suddenly lost all power.... got a push from a few nice randoms. Took me wee while but noticed that I had a couple fuses blown but also noticed that the circuit breaker I had installed in place of a fusible link had tripped... reset it then went on to my mates place. Chilled there for a bit then went home, circuit breaker tripped at least 10 times before I got home. When I left my mates I got a pretty decent way but after re-setting it the 2nd time about a km up the road or less it would trip again.... I haven't checked other fuses yet so unsure if more have blown... the lever on the circuit breaker was getting a little fiddly after having to reset it a few times so unsure if that could be the issue or whatever made the fuse blow. Any suggestions? Know it's probably not quite an easy thing to diagnose.
Posted: Sat Jan 14, 2017 10:36 pm
One more thing to add though I didn't lose all power only ignition power... so hazards and horn were still working
Posted: Sun Jan 15, 2017 2:05 pm
Pretty sure I've solved the issue... checked the rest of the fuses and they all seem ok so replaced them. I switched the battery switch off while I was inspecting some of the wiring when I noticed that one of the wires that goes to the circuit breaker was loose. Now the way I did the wiring for this was well terrible... instead of putting eye terminals on the end of the wire I had simply wrapped the wire around the stud and tightened up the nut. Now that I think about it for a wee while now I had to very gently turn the key to start it otherwise nothing would happen. Obviously the wire was loose so would only sometimes make contact when starting but stayed in contact while driving until the nut got a bit looser causing a short and blowing the breaker. Seems legit right? So I did it properly and crimped eye terminals on the end of the wire and hooked them back up to the breaker. Starts so better now as nothing is loose! I'm yet to do a road test as my partners friend's car is up the drive and they have gone out so I can't move it..
Posted: Sat Jan 21, 2017 11:21 pm
by datsunboy
Yeah. Always make proper electrical connections.
A minor bad connection can cause all sorts of havoc.
Good to see you sorted it easy
Posted: Thu Feb 09, 2017 9:08 pm
Posted: Fri Feb 10, 2017 9:39 am
by 85_Z31
You seem to have a real knack with interior stuff Greg, nice work.
Posted: Fri Feb 10, 2017 12:40 pm
Haha I wouldn't go that far.... but thanks!
Posted: Sun Feb 19, 2017 7:02 pm
Seeing as I'm driving this up to the north island at the end of March I thought there was a few things I should do like for example up grade the headlights to semi sealed beams! Got this H4 high/low semi sealed conversion kit from work.
I'm going to upgrade the high beams to H1 semi sealed beams but thought I'd just do the high/lows to start with. It would appear that I'm having relay troubles again as the passenger side is very dim and high beam doesn't seem to go at all... so I'm wanting to upgrade from the metal latching relay to like a narva 5 pin or something. Been trying to find info online but I can't seem to make sense of the diagrams
also seems people like to use 2 relays,one for low and one for high beam. Is that overkill or a really good idea? I look forward to hearing what you guys have to say!
This is the old sealed beams
And this with the hi/lo semi sealed beams but obviously not functioning properly..
Posted: Sun Feb 19, 2017 7:06 pm
Relays are a good idea depending on how the car is set up originally, James and I have both done it, it's a bit of a pain to do but worked really well for me. Looks like a grounding issue possibly?
Posted: Sun Feb 19, 2017 7:48 pm
I did re locate an earth wire that I found on the passenger side wiring but didn't seem to make a difference.
