Page 12 of 17
Re: Lewis's Datsun 1600 supercharger fitment and restoration
Posted: Tue Sep 14, 2010 10:17 am
by lewishorrell
yea it sure does still got to iron out a dead spot when rapid throttle is used eg slamming ya foot down straight away but that is just bigger pump jets and it should be sorted then up goes the psi im thinking 5psi should be enough
Posted: Tue Sep 14, 2010 8:01 pm
lewishorrell wrote: im thinking 6psi should be enough
Posted: Tue Sep 14, 2010 8:10 pm
by dirtyleppa
lewishorrell wrote:im thinking i should have got a turbo so i can wind in more than 5psi, and stop being a sissy :lol: :lol: :lol:
Posted: Wed Sep 15, 2010 12:05 pm
by lewishorrell
nah turbo for kids im thinking bart what size pully will i need for 6psi ill have to get bigger carb cos the one i have is at its limit i think still needs more fuel at top end and on acceleration
Posted: Wed Sep 15, 2010 5:20 pm
what size pulleys are you running now? Given your engine is the same displacement as the engine the blower was fitted to factory, it would be safe to assume that similar drive ratios would yeild similar boost numbers.*
(*depending on camshaft specs, and head flow characteristics)
Posted: Wed Sep 15, 2010 6:44 pm
by lewishorrell
its running 1:1 at the mo so maybe a lil bigger will be good it goes hard atm and doesnt seem to be playing up im almost considering leaving it for now until i get a L18 cos the compression ratio on my wee L16 is pretty up there got to be careful.
Posted: Thu Sep 16, 2010 4:16 pm
If you're going to change engines, I'd strongly reccommend a blower friendly (and lumpy!) cam grind, as well as using an L20B head. (they roll quite a big port, and can't hurt your CR either.
Posted: Tue Sep 21, 2010 7:53 pm
by lewishorrell
a few things ive been doing in the last week
Posted: Thu Sep 23, 2010 10:04 pm
by lewishorrell
some bits my brother and i have machined up for suspension and my new air filters
Posted: Sun Sep 26, 2010 6:50 pm
by lewishorrell
